Temps dropped today and my neighbor said he could help with pulling the boat out. I piloted the SV211 around to the ramp ~ 10 mins but dang, cold day it was not getting up to full temp. Trailer was waiting in the water, so loaded it on anyway.
Then my RV antifreeze hose was the wrong one. Had some electrical tape to beef up the OD & in the mean-time the engine cooling off more
Revved it up and sucked in 12L of RV straight-up, no draining. Got back to my place and 1st pulled my heater core drain - that looked good, antifreeze/pink there, last year it was pretty clear water. Then I took samples from the block at the knock sensors. It was pinkish but definitely diluted. I am pretty sure my T-stat was near closed, but I do think there is a little circulation port (see pix of gasket)
Put the samples in the freezer @ 0 DegF, -17 DegC. After 5 hours it did freeze into a slushy mix per the photos. In order to crack steel you'd need more force than this mix would apply. But it illustrates the margin of error on the thermostat, the final mixing, and what your low-temp target is. The rest of the system - trans cooler, impeller, water pump, exh manifolds, piping will have nearly 100% antifreeze, as that gets good flow from the impeller outlet.
