How to reset the circuit breaker on a 2023 G25 stern thruster?
  • RoboSanLucas
    • Jul 2019
    • 4
    • Salt Lake City, UT
    • 2023 Super Air Nautique G25
    Recently picked up a 2023 G25 and our first time out on the lake, the thrusters stopped working. Didn't ingest anything, maybe just ran them too hard? The graphics on the screen are all working and act as if it should be thrusting fine, but no sipnny. I'm thinking we tripped a breaker or something? Does anyone know how to reset the circuit breaker for the NISA? Thanks in advance!
  • Scooter G
    • Jan 2022
    • 1410
    • On a Lake in Idaho
    • 2022 G23 ZZ8
    Not sure if you took a glance at this, FWIW:
    https://www.planetnautique.com/vb5/f...-threads-tried
    Occasionally our thruster just doesn't work, doesn't happen often, it's just kind of fickle, it's almost like it's being lazy and takes a little break from action, and then it's fine again, go figure. I do see a dramatic voltage drop on the screen when applied, like down to 11 - 11.4 volts with the boat running, not sure if that's normal, but it does tell me it's sucking a lot of juice.
    • RoboSanLucas
      • Jul 2019
      • 4
      Sorry for the slow reply, but yes. We've noticed the high voltage consumption too, which I know is expected for these thruster systems. They consume a lot of juice.
      Update on our system: We did find some messages in the diagnostics that seems like there is a CAN/Bus communication issue with our system. It has worked occasionally since it first stopped, but it seems to be intermittent for us. I'll read through the thread you shared Scooter and see what else I can find. Thanks!
      • charlesml3
        • Jan 2008
        • 2478
        • Lake Gaston, NC
        • 2022 G23
        I'm going to send you a DM. Call me and let's walk through some things.
        -Charles
        • charlesml3
          • Jan 2008
          • 2478
          • Lake Gaston, NC
          • 2022 G23
          For those playing the home game, a "No CANBUS Comm" error means the controller isn't getting power. There are several possibilities for this.
          • Kbrix
            • Jul 2025
            • 1
            • Granite Bay California
            • 2023 Nautique P25
            We have had the same issue and have tried to update or reprogram and the updates fail
            or the reprogram shuts everything off. Any tips would be appreciated.
