Throttle failed for 3rd time
  • tomsmith
    • Oct 2016
    • 62
    • north dakota
    Does anyone have any ideas? I have had three new throttle drive by wire wire put in my 2017 GS 20 that currently has 300 hours on it the first one failed at 25 the next at 150 the next 202 and now it’s not working again
  • jpwhit
    • Aug 2016
    • 688
    • Cary, NC
    The Nautique Throttle Base Assemblies are well known for having reliability issues, but this seems a little crazy. Would make me wonder if there is a short in the wiring harness somewhere putting too much load on in. If so, could be really hard to find because it would likely be intermittent. Because if not, there would be other more persistent symptoms.
    • tomsmith
      • Oct 2016
      • 62
      • north dakota
      Well the dealer put all of them in and never suggested it anything was smearing except that they thought nautique needed a different supplier also my friends gs 22 had one go bad and also my 210 went bad once
      • jpwhit
        • Aug 2016
        • 688
        • Cary, NC
        Yes, the Throttle Base Assembly Nautique uses are made by Livorsi and certainly have reliability issues. And I agree Nautique should be doing something to correct this issue. But it's been a problem since they switched to this assembly in 2015/2016. But they just keep using it.
        But with that said, 3 and possibly 4 failing in one boat within that amount of hours is still outside the norm. I've broken one down and analyzed why they fail, and the design certainly needs improvement. And running higher than normal current through it would certainly kill it faster.
        • tomsmith
          • Oct 2016
          • 62
          • north dakota
          I have talked to Russel at nautique in the warranty department before but no solution
