Hi guys. New member and have a question about my brother-in-laws '92 SN. I'm familar with tourament inboards as I have a '86 American Skier. I talked him into this boat after he skied and drove my boat so I feel a bit at fault for this issue.
Here are his boat specs;
'92 SN
5.8 Pro Boss carbed
Pro-Tec ignition
44MPH @ WOT
Sorry but don't know the RPM
When you run it at WOT for 30-90 sec. the boat will just die. Like someone just turned off the key. It doesn't happen all the time either. About 25% of the time. After it dies, you can start it right up again like nothing ever happened. It runs great until the next WOT run that it shuts down again. The gauges (temp, oil pressure, etc.) are all well within any critical limits. I thought that it might be a high RPM limiter but that should just make the boat start missing until the RPM drops under the limiter range. I'm not familiar with the Pro-Tec ignition but I assume that it's a first generation ECM that was a precurser to a full blown EFI engine monitoring system. I've changed the plugs, filters and fluids. Didn't help. Any ideas? Thanks so much for you help.
'92 SN
5.8 Pro Boss carbed
Pro-Tec ignition
44MPH @ WOT
