2002 SN 196
I replaced the steering cable a few years ago, and this problem followed at some point. There is play in the steering, that shows up as the rudder unloads while turning and transitions to loading the other side. The rudder, rudder arm has no play, no leaks, its solid. As you can see from this video, the play is upstream from the rudder assembly. I am rotating the rudder back and forth by hand in the video to show the play that you can observe at the tube. I have also replaced the helm.
My steering is butter smooth, 2 finger steering. Only this shimmy of the rudder as it rotates through the turn that drives me absolutely crazy.
IMG_1831small.mov
IMG_1831small.mov
