2019 Nautique G23 - Lync screen Gauges going out but not entire sync screen.
  • Ryan_2018_G23
    • Jul 2019
    • 27
    • Murrieta, CA & Lake Keowee, S.C.
    • Previous: 2018 G23 Current: 2019 G23
    Check out the videos... I can't even explain it:
    https://www.icloud.com/sharedalbum/#B2I5idkMwo78Yl
    In second (shorter video) the gauges do come back on at the very end of video.
    This has been going over for about 2 years now and can't figure it out. Dealership can not get it to repeat on water test, but happens to us every time we go out. When surfing the wave with drop out completely ,as well, and all gauges drop out and cruise control drops out. No changes in throttle action. Surfer runs into boat... It is dangerous.
  • Ryan_2018_G23
    • Jul 2019
    • 27
    My previous post trying to explain: https://www.planetnautique.com/vb5/f...uges-drop-to-0
    • jpwhit
      • Aug 2016
      • 689
      • Cary, NC
      I'm fairly certain you're experiencing a CanBus fault. On the newer generation Nautique's they have really overloaded the single CanBus in the boat. They really need a much more resilient and fault tolerant design such as is used in automotive with multiple buses where safety critical systems such as throttle and boat speed are on a separate bus from non-critical systems such as ballast pumps, tab actuators, lighting and such. That would also make diagnosis much easier. Building some logging and diagnostic tools into the system would also go a long way.
      Unfortunately, given the number of devices on the single bus, this is difficult to diagnose. Especially remotely. If I were at your boat in person, I'd connect up a CanBus logger and bus monitor to figure out what's going on. Given the cost of these boats, maybe Nautique can send someone to your location to diagnose the issue.
      • Ryan_2018_G23
        • Jul 2019
        • 27
        Thanks for these thoughts, jpwhit . Will these show on a fault screen anywhere as we are not getting fault popping up? We have had terrible issues with batteries / low voltage / failure... Have replaced the batteries 4 times in 4 years with only 240 hours on the boat. The battery tender also went out so had to buy a new one of those. Not sure if any of these are related but thought I should bring it up.
        How challenging / costly is the CanBus fault repair? I am down on Lake Keowee in South Carolina.
          • 17235
          jpwhit is absolutely on the right track.
          I ran your issue by a friend of mine who is an engineer at Nautique, and he said you're likely losing CAN communication. He suggested starting by checking the CAN wiring to the LINC screen. It may be as simple as a loose connection.
          • jpwhit
            • Aug 2016
            • 689
            • Cary, NC
            With issues with the CanBus, they often do not show up as faults on the LINC screen. That's partly due to the limited diagnostics and error checking built into the LINC screen for problems with the CanBus. There are many different issues that can occur with the CanBus.
            The two most common fault conditions fall into two general categories. First is a CanBus wiring issue. Simply a break in the wiring or connectors somewhere along the bus. The bus consists of a pair of wires designated as Can High and Can Low. At each end of the pair of wires are 120 ohm termination resistors. If there is a point where there is an electrical break in either Can High or Low, the bus won't operate.
            The second general category of CanBus fault is a device on the Bus somewhere that has failed in such a way that it's blocking the bus by either shorting it out or generating electrical signal that disrupts the bus. In theory, devices should really be designed such that they shouldn't fail in this way. But in theory really depends on the diligence of whoever designed the overall system. It's extremely rare for example to see this kind of failure in the automotive world. Otherwise, the car companies would get a big black eye for building cars that were unreliable or really hard to repair.
            It even worse when you have a CanBus fault that intermittent such as this case. That can be due to an intermittent wiring fault or a device on the bus that failing and disrupting the bus intermittently. That's were having very good logging and data recording built into the system for diagnostic purposes can really help. Otherwise, you can only look for the problem while the intermittent condition is happening, or you can just start disconnection or replacing CanBus devices on the bus until the problem just stops happening. But that can get expensive quick.
            Given the limited diagnostics built into this system, and the level of complexity and number of devices on the bus in these newer boats, it's pretty much impossible to predict how long it would take to find the issue, It's the proverbial needle in a haystack. A lot depends on the experience and skill of the technician working on the problem.
            It also doesn't help with the limited technical documentation that's available on these boats. For example, you would assume it would be easy to get a list of all the devices on the CanBus in your boat. But I'm not aware of the availability of that information. I'm not even sure the dealer service technicians have a clear definitive list. I can take an educated guess just based on my experience with boats. This would be a partial list off the top of my head.
            Engine ECU
            LINC Screen
            Keypad
            Joystick / Aux LINC Control
            PDM 1
            PDM 2
            PDM (not sure how many PDM in this model)
            GPS Puck
            Zero Off or Cruise Control black box
            AirMar Biducer
            NSS Actuator left
            NSS Actuator right
            Center Tab or Gate Actuator
            Various Stereo Components (sometime these are on a separate NEMA 2k Bus)
            • bturner
              • Jun 2019
              • 1793
              • MI
              • 2016 200 Sport Nautique
              I'm in awe of jpwhit 's technical skill set. Great information as usual.
              On another somewhat related note.....
              Saw an article a couple weeks back discussing classic cars in which the author lamented that there will be no "next generation" of classic cars due to the nature of the electronics currently being utilized and the near impossible task of restoring or finding replacement parts for cars 10 - 20 years from now. I think the same will be said of boats past 2010 depending on the features of the boat.
              Right now you can still buy boats that are 20 years old and make them work as designed and reliable. How are you going to do that with one of these electrical nightmares? I guess where there's a will there's a way and maybe the aftermarket will develop and step in but right now that next generation of used boats is not looking promising to me. Am I alone in thinking the used boat market could see some serious challenges in say 5 years when these electrical beasts age out of warrantee?
              • SilentSeven
                • Feb 2014
                • 2251
                • Bellevue WA
                • 2004 Nautique 206
                Interesting take bturner. We have initial experience on how the proprietary systems have aged (looking at you Faria) - not well. I'll speculate that the future looks something like this...
                There will be 'available parts' that have sufficient market demand (shared across multiple boat manufacturers, have sufficient failure rate to drive ongoing supply) and then there will be the 'unavailable parts' - items that are so curated and niche that no one will continue manufacturing.
                If you have a legacy boat with a failure, the boat will be repairable if your high volume part fails. However, if your boat is dependent on a low volume niche part, it's effectively going to be unrepairable. The likely reality is that any boat will have a mix of both so you end up with some systems remaining functional and others that can't be repaired. Which systems are repairable or not will determine if the boat remains in service. Owners may choose to keep a boat in service if a non-essential system fails. In response to this, a secondary market will develop where enterprising businesses buying unserviceable boats, harvesting the e-bits and offering them for sale as repair units. Today we see these markets for cars, appliances etc but I can't recall seeing a seller focused on the Nautique / Malibu / Mastercraft / Supra..et all used components.
                The parts supply above also requires development of service businesses willing to do this type of diagnosis and repair. I'm no dealer expert but I don't think this type of work aligns at all with what they prefer to do...it's likely provided by skilled independent servicers. Not sure I have seen this type of business either.
                Are there there are enough owners and used boat buyers who want purchase / maintain older boats that are subject to this market? Dunno.
                Curious area to speculate on....
                Bellevue WA
                • Ryan_2018_G23
                  • Jul 2019
                  • 27
                  NautiqueJeff jpwhit Thank you so much for all the information. Is this something I can trouble shoot myself and if so, where is the best place to start. It does go in and out (and has for years) so the likelihood of a loose connection seems plausible. Is there a diagram or anything to follow? Where is it all located in the boat? Under steering column behind the line screens?
                  • jpwhit
                    • Aug 2016
                    • 689
                    • Cary, NC
                    The CanBus wiring runs all over the boat through most of the wiring harnesses to reach all the devices in the boat. The list of devices I listed in post number 6 should give you somewhat of an idea of all the places it runs. I'm not aware of a wiring diagram or other documentation on the CanBus available for your year boat. I can't recall exactly how the wiring on the Nautique is labeled off the top of my head, but on MasterCraft's there are little white bands on the wires at each connector. The CanBus wires have lCANL and CANH on those labels. Nautique probably has similar labels.
                    • Cosmo
                      • May 2018
                      • 24
                      • CONNECTICUT
                      • 2020 GS22 2006 CC Super Air Nautique 210 Limited
                      I'm having this exact same problem. Oddly, I can recover the data/functionality with a good slap of the dash above the Linc Panoray, which leads me to think it's a loose wire/connector. Did you get an answer to your questions? I'd like to know how to remove the Linc Panoray and check the connections.
                      • new210
                        • Aug 2012
                        • 29
                        • B.C. Canada
                        • 2015 G21
                        I wonder if this could be what is causing my boat to shut down, I have a 2018 g 23, I will be surfing or driving and then the boat will completely shut off? I recycle the battery switch and then it resets and off we go again until it shuts down. Candid a day or only ten minute, never know when it will happen? I replaced the crankshaft position sensor but it obviously something else? Thoughts?
                        • ohlhauser13
                          • Apr 2026
                          • 2
                          • Bismarck north dakota
                          I have a 2018 g23 and am wondering if anyone has a wiring diagram for the linc or has a setup they can share that they use to test the screen out of the boat. I want to bench test my screen it will not power on in the boat but i dotn believe the screen is the issue.
