Hi All
My boat has about 400 hours on it and it's running rough at idle and various places in the rev range when driving. Its running rough enough the the boat is shaking and vibrating a bit. The boat is 100% stock. Oddly enough, when I put the button to rev the motor without the prop engaged it seemed to smooth out a little. Not sure if that has anything to do with it.
Anyway, I'd like to get a sense of where to start with a rough running boat: Here's kinda my list - Is this the best place to start?
1. Check that the kill switch is pressed all the way down (it was cutting out previously because of this). Checked it - not the problem.
2. Clean the dirty spark suppressor/air filter.
3. Clean the throttle body (it looks dirty)
4. Clean the battery cables (it has a new battery, any chance that contact with the battery is causing running issues?)
5. Change spark plugs
6. Change fuel filter
What else should I check? Anything I'm overlooking?
