Is it going to freeze?
  • Mikeski
    • 2908
    • San Francisco, CA
    It's been getting cold in California the last few nights so I did a little temperature recording last night, check it out.
  • Proud2BeCC
    • Mar 2004
    • 201
    • Warsaw, IN
    • 2002 Sport Nautique
    RE: Is it going to freeze?
    Very interesting....Sure does show that during the cool down periods that the motor box area does stay considerably warmer than the other areas.
    _____________________________________________
    Proud2BeCC
    2002 Sport Nautique
    (NDT) New Dimension Tower
    TowerBinimi Binimi Top
    Clarion CMD5
    • MNSuperAir
      • Sep 2005
      • 591
      • St Paul
      • 2016 SAN 210
      I like that. Can you add the actual outside temp to your chart. That would help some. Also, V-drive or direct drive? I have a feeling the a V-drive would stay more warm.
      2016 SAN 210
      2006 SANTE sold
      2001 SAN - sold
      1991 Sport Nautique - sold
      • jhiestand
        • 786
        • Columbus, Ohio
        • 08 Super Air 210
        Definitely makes sense, as I've noticed my engine compartment stays warm for quite a while once we get off the water as the engine slowly cools. Obviously it's relatively insulated from the rest of the boat.
        Great info!
        '08 Super Air Nautique 210
        • surroundsound64
          • Jul 2005
          • 2148
          • Longview, TX
          • 2026 S23 1981 Ski Nautique
          Re: RE: Is it going to freeze?
          Could we get the solar flares calculated into there also?
          Yellow_Flash_Colorz:
          Just kidding. :mrgreen:
          2018 SAN 230
          1981 Ski Nautique
          Sold - 2011 Sport 200V
          Sold - 2000 SAN
          • Adrian
            • 175
            • Spain Europe
            Yesssss, this is something very interesting. I used to ski until the first expected freeze. But I always have thought the engine must be warmer with the engine cover, boat cover...
            I don't understand why the temperature of the "top boat" and "side boat" is higher between 8 am and 4.30 pm. Is the boat outside exposed to the sun?
            • Sinkoumn
              • Jun 2006
              • 578
              • MPLS - St. Paul, MN
              • Super Sport Nautique
              Adrain, I'm guessing it's like heating up a burrito - hot on the outside and icey cold in the middle (heat can't penitrate into the engine block as fast as it heats up the outside of the boat).
              [url=http://www.neustonboards.com][i][color=Blue][size=4]Neuston Boards[/size][/color][/i][/url]
              [size=4][i][color=green]Nautiques[/color][/i][/size]
              • Mikeski
                • 2908
                • San Francisco, CA
                Here are more details.
                The temperature recorders take a sample every second and record the average reading every 15 minutes. The graph is a line of the samples over the 24 hour period.
                My boat is on it's parking pad on the side of my house covered only by it's dark blue full side sunbrella cover.
                The recorder labeled Motor is inside of my V-drive compartment sitting on the valve cover, so it is measuring the temperature of the motor compartment. I figure the block temperature is probably going swing about 3-5 degrees less than the temperature I recorded.
                The Side Boat recorder was sitting on the step pad behind the trailer fender on the north side of the boat. That recorder is sheltered from wind and sun, it should represent the ambient temperature as measured in the shade. It's very close to the weather report.
                The Top Boat recorder is on top of the cover with it's thermocouple exposed to all the elements.
                Adrain, the motor is insulated from the ambient temperature. This results in a buffered temperature swing where the peaks will be less than ambient, the dips will be more than ambient, plus there will be a temperature lag until saturation is reached on both the up/down swings.
                It is also of interest to notice how the increasing motor temperature is much steeper than the decreasing motor temperature.
                What does all of this mean? Basically we don't need to worry about our boat's freezing until the AVERAGE daily temperature drops down into the mid 30's. The only times I have heard about blocks freezing is after three or more days of temps where the peak temperature did not break the mid 30's.
                • Edwin
                  • 219
                  • St. Louis
                  Great info Mike...thanks for sharing!
                  • darrel409
                    • Jul 2004
                    • 566
                    • San Dimas, So. Cal
                    Thanks for adding more details... In my mind i was picturing mikeski cussing out his alarm clock every 2 hours and going out to the cold to take boat temp measurements. Yellow_Flash_Colorz:
                    Although, BKH may take this opportunity to confirm the findings by taking boat temps everytime his new littlegirl needs a
                    night feeding. Yellow_Flash_Colorz:
                    Thanks for the valuable info...31 last night where the boat lives. I dont "winterize" but i can sleep well.
                    • bkhallpass
                      • Apr 2005
                      • 1407
                      • Discovery Bay, CA
                      Is is great info. I was almost concerned enough to go throw a lightbulb under the motor hatch.
                      Funny, I had the same picture of Mike running out every 2 hours. If you know Mike, if he wants the info, he'll get it one way or another. But, he's also a gadget guy and I bet he had as much fun playing with the sensors as anything else.
                      One thing I've learned in my two weeks of fatherhood. Choose very carefully the woman you decide to have children with. My wife's awesome. Only been woken up once in two weeks.
                      Looks like your Trojans got my Bears yet again Darrel.
                      BKH
                      2001 Super Air
                      • surroundsound64
                        • Jul 2005
                        • 2148
                        • Longview, TX
                        Mike, that is AWESOME! Thanks for clarifying the top and side recordings! It's supposed to get into the 20s tonight but it's been 70-80 the last few days and is supposed to get in the 40s during the day tomorrow. I haven't winterized because I've been trying to go out to a heated lake. I was a little worried it might be too cold and I'd have some problems, but now I can rest assured!!!!
                        Thanks again Mike!
                        2018 SAN 230
                        1981 Ski Nautique
                        Sold - 2000 SAN
                        • Adrian
                          • 175
                          • Spain Europe
                          Thank you very much, Mike. Really interesting.
                          • darrel409
                            • Jul 2004
                            • 566
                            BKH, I'll stay off my "Trojan horse" til after Saturday and UCLA. This city rivalry is huge and it makes me nervous.
                            Thanks again to Mikeski.
                            • aquasox
                              • Aug 2004
                              • 14
                              • Central Texas
                              Awesome info. I just got back in town and found it's getting down to the upper 20s tonight (low 50s tomorrow afternoon) and I was about to head to the marina to open the drain plugs.
                              I think I can relax enough to go to bed instead.
                              thanks,
