ZR6 Drain Plug Swap
  • Osubucki00
    • Oct 2017
    • 7
    • Atlanta
    ZR6 Drain Plug Swap
    Hello, this is my first post and I have a quick question. I have a 2008 SAN 220 with the ZR6 390 engine. I’m about to winterize it myself and have all the info to get it done properly. My question is has anyone ever swapped the brass drain plugs for the raw water system with the blue winged drain plugs? Good idea or bad? Just thought it would be easier and quicker in the future to add and remove drain plugs. Click image for larger version
  • charlesml3
    • Jan 2008
    • 2482
    • Lake Gaston, NC
    • 2022 G23
    Yea my neighbor installed brass petcocks where the blue plugs go. Now he wakeboards year-round, so keep that in mind. If you're winterizing once a year, I really don't see the value in changing them out.
    -Charles
    • Osubucki00
      • Oct 2017
      • 7
      • Atlanta
      Thanks, that’s actually a great idea but I only do this once a year so not a big deal.
      • Ckowals1
        • Aug 2019
        • 139
        • Mooresville, NC
        • 2019 G23 Previous: 2008 SAN 230 Team Edition
        i swapped with brass petcocks in my '08 230.
        have a buddy with an '11 210 who swapped out the vdrive drain with the blue quick drains - hasn't had any issues for the few years its been used.
        As long as the threads are the same to make a watertight seal, I don't see any issues with using all blue winged quick drains
        • Jonny Quest
          • Aug 2014
          • 447
          I'm not a big fan of plastic stuff in critical areas. I would replace the plastic thingy with a brass petcock:
          JQ
          • gary s
            • Mar 2015
            • 335
            • Algonquin IL
            My 95 had the blue plastic ones, they may have been Mercruiser ones, - sometimes the oring would fall off then you'd be looking all over for it. I now use the above ones in everything.
            • Osubucki00
              • Oct 2017
              • 7
              • Atlanta
              Wow thanks for the info! I’m going to get me some of the brass petcocks!
              • Osubucki00
                • Oct 2017
                • 7
                • Atlanta
                JQ
                Do you have a link to those?
                • Jonny Quest
                  • Aug 2014
                  • 447
                  https://www.mcmaster.com/products/petcocks/
                  Drainage Valves - Removable T-Handle
                  1/4"
                  JQ
                  • DoubleUpDisaster
                    • Feb 2020
                    • 79
                    • Southern WI
                    • 2019 G21
                    I need to install a drain like that in the line just downstream of the oil cooler on my ZR4. That hose is supposed to come off per the manual, it’s a pain to wiggle off, and a TON of water comes out even after draining everything else.
                    I put one of these on one of these and cut the fitting into my raw water inlet hose, works great to run the boat in the driveway. I’m going to have to find something similar, but maybe more streamlined, for that oil cooler line.
