Went out yesterday and after being under way a short time I watched all of the needles on all of the gauges drop for a split second, then continue to function normally. An hour later all gauges ceased functioning completely, large and small. No LCD display - nothing. All had been working fine.
The four smaller gauges had been recently repaired, so I suspected that a connection might have come loose after reinstalling the console. Upon removing the console all plugs were snug with exception of a small rectangular plug, which wasn't fully engaged and latched. Problem solved I thought.
I started the motor but there was still no life in any of the gauges.
Checking the fuse and breaker panels there doesn't appear to be a fuse or circuit breaker directly associated with the gauges.
I have the paddlewheel so no issues with water making it up to the gateway.
The behavior mimics a faulty connection, so I think I'll pull the console one more time and disconnect/reconnect all plugs and examine the metal prongs in the plugs. as well.
Any thoughts about what the cause may be or additional things to check would be appreciated.
Also, I found this 1-inch long bit of metal on the carpet under the console after reassembly. No idea what it is nor whether it came from inside the instrument console.
