2000 ski nautique..overheat under load
This topic has been answered.
  • nzltmp
    • Jul 2019
    • 28
    • michigan
    • 2000 ski nautique
    Have a 2000 ski Nautique that overheats when pulling a skiier.
    changed impeller. returns to normal quickly and won’t overheat when in idle or under low power…also doesn’t overheat when pulling a tuber.
    runs perfect outside of that/no engine miss
    water strainer is clear of debris
    suggestions???
  • Answer selected by NautiqueJeff at 07-06-2024, 04:44 PM.
    nzltmp
    • Jul 2019
    • 28
    • michigan
    • 2000 ski nautique
    SOLVED
    YEP..stuck thermostat.
    buddy removed it and went to explain to his son how one works…it was stuck. Thank you all for the direction. What a great forum!
    • SilentSeven
      • Feb 2014
      • 2068
      • Bellevue WA
      • 2004 Nautique 206
      Many cooling issues are solved by ensuring there are no air leaks in the intake side of the raw water feed. I'd start there - check all hoses and clamps to make sure they are clean and tight. Also make sure your strainer oring is in good shape.
      If that does not solve it, I'd remove the engine thermostat and run it without one and see if anything changes.
      My guess - you have an air leak that only shows up under higher suction levels you'd tend to experience at high RPMs. It's also possible you have a thermostat that's not fully opening.
      Sent from my Pixel 7 using Tapatalk
      Bellevue WA
      • Michael Crouse
        • Jun 2017
        • 79
        • Iowa
        • 2000 Ski Nautique
        You may have some plugged ports from a blown up impeller. My 2000 sk inatique had parts of an impeller around the thermostat. Heat would creep up when skiing. Might be with clearing all the areas around your thermostat and all your hoses coming off the water pump.
        • peteb
          • Jun 2005
          • 41
          • Ohio River, Cincinnati Area
          • Cincinnati, OH
          • 2003 Sport Nautique 216 (current) 2000 Ski Nautique (2nd SN) 1990 Ski Nautique (1st SN)
          Agree with previous posts. Make sure your not sucking air and if you haven't changed the Tstat in a while its a good time to do that. Make sure to get new gaskets also when you order the stat.
          1990 SN / Cincy, OH
          • jpwhit
            • Aug 2016
            • 642
            • Cary, NC
            It's not likely an air leak. Air leaks typically behave the opposite of what is described. Overheat at low speed, get better at high speed.
            Most likely it's a worn-out thermostat that just doesn't open wide enough anymore.
            Less common, but causes the same symptom, back around 1998-2000, there was a batch of defective GM Marine circulating pumps produced. The metal impeller wasn't properly press fit to the pump shaft. Then with enough age, the impeller would start slipping on the shaft.
            • Jonny Quest
              • Aug 2014
              • 434
              I concur with jpwhit. My Spidey-sense says T-stat.
              JQ
              • nzltmp
                • Jul 2019
                • 28
                • michigan
                • 2000 ski nautique
                Thanks everyone
                replacing thermostat today..will advise on results.
                btw. Lake impeller replaced last year..old one didn’t come apart…so no clogging of passage ways
                • nzltmp
                  • Jul 2019
                  • 28
                  • michigan
                  • 2000 ski nautique
                  SOLVED
                  • SilentSeven
                    • Feb 2014
                    • 2068
                    • Bellevue WA
                    • 2004 Nautique 206
                    Thanks for posting your fix! Great to hear you are back up and running.
                    Bellevue WA
