I searched around and can not find a chart for recommended fuel pump PSI relative to horsepower and/or top RPM. Something such as approximate recommendations for example 300-350 horsepower or 5K RPM would be 5-6 PSI and 350-400 horsepower 5,500 RPM would be a range of 6-8 PSI. I am doing some trouble shooting and want to make sure my fuel pump is working properly. I installed a new intake last week as well as a new power valve in the carb. Took the boat out Saturday and the boat ran good up to 5050 RPM where it had an occasional cutting out or missing...almost like the rev limiter but not a consistent miss like a rev limiter feels. I checked the timing before I left and it was 12 degrees.
On Monday I am going to get a gauge and verify fuel pressure as well as pull the bowls and check for any debris. Total rebuild on the carb in April and new fuel pump in August. Last trip out in the boat before the intake swap the boat ran great with no problems and up to 5180 RPM with no cutting out/missing. If anyone knows where the fuel pressure should be that would help. Carb is a 4160 Holley 600 CFM. Any thoughts as to what else I could check would help. Timing was good but if I was running low on fuel pressure and the secondary bowls were running low I would think the engine would slowly loose RPM's and speed and not just a sudden miss or engine cut out.
Thanks!
Thanks!
