We recently just put our boat in the water for the season and after a few times going out noticed that the bilge fills up unusually fast. We pulled it onto the lift and realized that water only flows in when the engine is on. In order to attempt to isolate the leak we pulled the boat completely up and hooked the engine up to a hose to see if the water would still leak and it did.
I looked at the packing around the shaft and I don’t believe thats the cause of it. All the winterization drain plugs are fully in and not leaking either. There are no obvious leaks however the water still pools up at an abnormal rate.
Any ideas? (We are not the greatest mechanics so don’t be afraid to shout out something obvious)
