Dead Dash on 2001 210
  • 01OGsuperair
    • Dec 2021
    • 11
    • OH
    • 2001 Super Air Nautique
    Rebuilt engine and have been trouble shooting an issue with my rpms limiting when trying to rev but today I went out to work on take off throttle cable to see if its the cable/PP but I have no power to my dash. I can hit the switch to turn on the bilge and that runs and my ballast pumps run but I don't get anything to the dash. Am I missing something simple or is this more of a long process to find the issue? Thanks for any input
  • 01OGsuperair
    • Dec 2021
    • 11
    • OH
    Got my volt meter out and I have power at the plug that plugs into the keypad. Is there a way to test the keypad for issues or to see if its something different and is there a way to start this thing at all without having to order a new keypad????
    • jpwhit
      • Aug 2016
      • 641
      • Cary, NC
      You can send the keypad to Nautique and they’ll test it for you.
      • bturner
        • Jun 2019
        • 1685
        • MI
        • 2016 200 Sport Nautique
        I'll take "check the stupid stuff that bites me in the butt on a regular basis" for $50 please.
        Safety lanyard attached and working correctly? Since you have that meter out I'd ohm it out as well.
        • functionoverfashion
          • Jun 2017
          • 511
          • New Hampshire
          • 2003 SANTE
          Agreed on checking simple stuff first. Faulty safety lanyard switches do exist.
          As far as running things without the keypad, I do think that's been documented here. Some have wired in a hardwired system for ignition power and the starter in the event of a keypad failure. A hardwired hotwire, if you will. It's not super hard, search for keypad bypass maybe.
          • 01OGsuperair
            • Dec 2021
            • 11
            • OH
            It was actually the fuse panel on the kick wall I call it by the drivers feet went bad and wasn't allowing things to power up correct. Sent it in to Nautique and they tested the key pad and the fuse panel for me. Great service and quick turnaround.
