Impeller Change - Replacement G23
  • Scooter G
    • Jan 2022
    • 1450
    • On a Lake in Idaho
    • 2022 G23 ZZ8
    There have been a few posts and maybe a Youtube or 20 on the topic. I thought I would throw out a step by step for any that may want to attempt this on their own. Probably one of the easier things to attempt on your own. If you are not snapping pictures along the way, a fresh water impeller replacement can be done in under 30 minutes.
    Required tools: New Impeller & O-Rings, 1/2' ratchet or preferably a 1/2" breaker bar for leverage on the belt tensioner, 10mm deep socket or boxed end wrench for the pump cover, a pick or really small bladed screwdriver for the O-Rings, rags, a really bright light(s).
    Oh and, so I don't get called out on this one, chips & beverages
    I want to add to this 1st picture of the impeller below. Sometimes we get in a hurry, but when you pull your old impeller, check it for size against the new impeller. Very unlikely you got it wrong, but you'll save yourself a headache or worse, just to double check.
    Pull the port side locker panel, you can access what you need from here.
    1/2" breaker for belt tension pulley
    Lefty loosey, counter clockwise until belt is relaxed on water pump pulley
    Rock pulley preferably clockwise to align holes in pulley with the pump bolts (10mm)
    I've had this impeller pulley laying around for a while, have never used it. I've pulled impellers with pliers or channel locks before. I will give it credit for removing the impeller unharmed in one piece. Although I think this one would of slipped out, without much effort.
    Pick out cover O-Ring. There are also 3 O-Ring's that seal the bolts, and keep them from falling out into the depths of never seeing them again belly pan. I don't replace these but maybe every 2 or 3 change outs. Choose your own preference here.
    This will be user preference. Anything that moves gets white litho, and if it has threads, it gets anti-seize. It has always worked for me, not open for debate. Do what works for you.
    Coat the housing, impeller, and cover. You can also use soap as charlesml3 mentions below. This will make the impeller slip in easier.
    Clockwise rotation to make sure everything is seated and intact.
    Reseat belt. If you get a little wild in the process and knock the belt off of a couple of pulleys, there is a diagram. If not, I hope you took a picture 1st.
    Maybe a little over the top, but anything that gets changed on a regular basis, gets a label, everything (except for the light bulbs & underwear, those are pretty obvious). Too many toys to keep track of, and running to a spreadsheet sometimes get's neglected.
    I hope this helps if you have thinking of attempting this. Those that do their own maintenance can do this one with their eyes closed.
    I didn't show the new impeller slip in, but if you got the old one out, it's pretty obvious at that point. I would suggest a clockwise spin to get the impeller vanes headed the correct direction, but at the end of the day, one could argue that it really matters, they will take heed the direction they need to go. Be snug but soft of the bolt torque, you are threading into brass. Check for leaks on fire up.
    See you on the water...
    ~Scooter G
  • charlesml3
    • Jan 2008
    • 2481
    • Lake Gaston, NC
    • 2022 G23
    The only thing I'd add would be:
    - Coat the new impeller in hand soap or something to make it slip into the housing easier
    -Charles
    • Scooter G
      • Jan 2022
      • 1450
      • 2022 G23 ZZ8
      There in lies the White Lithium, if it moves...
      Coat the cover plate, housing, and impeller.
      And you are correct, thanks Charles, night and day easier.
      • uga5
        • Apr 2024
        • 2
        • GA
        Whoa - those hooks on your side engine cover panels look great. Where did you get them?
        • bturner
          • Jun 2019
          • 1732
          • MI
          • 2016 200 Sport Nautique
          Excellent write up. Love seeing these types of documented maintenance procedures.
          • Scooter G
            • Jan 2022
            • 1450
            • 2022 G23 ZZ8
            Best fold down rope hooks ever. Nautique nailed it with that one, out of sight, out of mind if you're not using them. Not sure what year they started putting those on the engine/locker panels. After using them, and I didn't have them, I would be coming up with something similar. Best thing, everyone knows exactly where the ropes go at the end of a session.
            • GMLIII
              • May 2013
              • 2820
              uga5 Nautique Parts. I ended up install 2 additional hooks like these on each side of the engine side covers for a total of 4 on each side of the stern locker areas.
              Rope Hanger - Nautiqueparts.com
              • Holy
                • Apr 2026
                • 1
                • Texoma
                • '19 G23
                The writeup looks good though the pics appear to have bad links. Anyone know of a similar post with Pics?
                • Scooter G
                  • Jan 2022
                  • 1450
                  • 2022 G23 ZZ8
                  Updated pictures (AGAIN), should be good to go
