I purchased a 2001 Air Nautique at the end of the season last year, it ran great and everything seemed very tight.
After dewinterizing and changing the oil I took it out for the first time this year. Everything seemed fine until I went to idle after a hot lap - oil pressure dropped and check engine light came on. Once I gave it some throttle the pressure shot back up to 60 where it seems to sit while cruising.
I’ve read a few forums and decided changing the oil sending unit might fix the issue which I did this past weekend and still have the same problem. Does anyone have other suggestions for moving forward? How concerned do I need to be about the check engine light? Am I still okay taking it out until I get this resolved?
PSI is 40 when starting the boat, 60 WOT, and drops to 30/35 at idle. I will say it has been on the colder side when I’ve gone out to test things (roughly 50 degrees).
