S23 - can I run boat lift using generator until I get power to my dock?
  • SABdaddy
    • Nov 2016
    • 32
    • Raleigh
    • 2022 S23
    Pic for attn. bought a lot at Gaston with a boathouse/lift. Have had power run to boathouse yet. Can I use a generator to power the lift so I can keep boat at the lake?
  • Scooter G
    • Jan 2022
    • 1333
    • On a Lake in Idaho
    • 2022 G23 ZZ8
    The short answer is if it is electrical you can plug it into a generator, all day long.
    I'll let someone else chime in with the technical 120/240v, amp draw, generator specs, cord size, GFI, lift rating details, you know, the little things.
    Love the boat house, good score!
    • MN Ryan
      • Aug 2020
      • 1285
      • Maple Grove, MN
      • 2007 SV-211 TE
      That's a killer boathouse. Man, I would love that.
      • srock
        • Oct 2008
        • 1072
        Any electrician can review the power requirements and design and provide a cord-plug for the appropriate sized generator to run the lift. Are those real pavers on the deck?
        • fsts2k
          • Nov 2004
          • 219
          I did for a year.. was a hydraulic lift vs cable but that shouldn't matter. I did not use a long extension cord due to potential amp pull.. otherwise, it worked fine for me.
          • charlesml3
            • Jan 2008
            • 2456
            • Lake Gaston, NC
            • 2022 G23
            You'll need about 5500 watts to drive the lift. I've come across this several times in my lift business here on Lake Gaston.
            -Charles
            • SANonTellico
              • Aug 2014
              • 302
              • Tellico Lake, TN
              • 2022 GS22
              Congrats on your purchase…..good looking boathouse!
              You can take the plastic cover off around your lift motor, there will be a label on the motor that shows the required power (volts/amps). Then you just need a generator that can provide that amount of power out of a single outlet.
              Caution: The bunks on your lift look like they’re for a pontoon boat, you may need to replace them with bunks that are appropriate for a V-Hull boat.
              Previously: 2015 SAN 210
              • jpwhit
                • Aug 2016
                • 542
                • Cary, NC
                Close friend did this when building his house / dock on Gaston last summer before the power feed was run to the dock. He used a 6000 watt 240v generator. Worked great until someone broke into the storage room on the dock and stole the generator. He's on the Lizard Creek cove at Gaston.
                • charlesml3
                  • Jan 2008
                  • 2456
                  • Lake Gaston, NC
                  • 2022 G23
                  They most certainly are. They will need to be removed and replaced with v-hull brackets and bunk boards.
                  -Charles
                  • JayG80
                    • Dec 2006
                    • 206
                    • Santa Fe, TX
                    • 2007 Ski Nautique Sold 2002 Ski Nautique
                    Cable clamps are not spaced properly. I would add one more above the lower clamp (aka wire rope clip) per link. https://www.fehr.com/img/product/des...llation%20.pdf
                    • charlesml3
                      • Jan 2008
                      • 2456
                      • Lake Gaston, NC
                      • 2022 G23
                      Meh. They could be a little closer together but it really doesn't matter. Two cable clamps per cable is also perfectly fine for this application.
                      -Charles
                      • srock
                        • Oct 2008
                        • 1072
                        Just remember, "never saddle a dead horse". The saddle needs to be on the live load cable.
                        • SABdaddy
                          • Nov 2016
                          • 32
                          • Raleigh
                          • 2022 S23
                          Yes they are real pavers. Thx for the message back
                          • SABdaddy
                            • Nov 2016
                            • 32
                            • Raleigh
                            • 2022 S23
                            Another question. Boat lift motor has 240v 3 prong on plug. My generator has a 240v 4 plug (female). Talk to me. Is there an extension cord converter that folks have used or seen?
                            • charlesml3
                              • Jan 2008
                              • 2456
                              • Lake Gaston, NC
                              • 2022 G23
                              I'll send you a DM. Call me tomorrow.
