Winter project - traveling prop change kit
  • SilentSeven
    • Feb 2014
    • 2184
    • Bellevue WA
    • 2004 Nautique 206
    Always wanted a good traveling prop kit. Requirements were:
    - single kit that has everything
    - hardsided unit to protect the prop
    - needs to fit in the aft underseat storage area in our 2018 Honda pilot. Don't want to keep this in the boat.
    The recent expansion of options within contractor 'packout' systems provided the inspiration. Turns out the $30 Rigid unit will both fit the prop (Acme 422) and just fit in the car's storage compartment. Other boxes (DeWalt, Milwaukee) were just a tad too tall. A little custom foam work and it's perfect - prop, puller and a side tray with pins, spare key and wrenches.
    Click image for larger version  Name:	PXL_20240113_212535908.jpg Views:	0 Size:	121.8 KB ID:	673253
    Click image for larger version  Name:	PXL_20240113_212518865.jpg Views:	0 Size:	107.0 KB ID:	673257
    Bellevue WA
  • MN Ryan
    • Aug 2020
    • 1390
    • Maple Grove, MN
    • 2007 SV-211 TE
    Very nice! Did you buy the foam or repurpose it from elsewhere? Thanks for the inspiration.
    That reminds me that I need to drop a prop off at the Prop Doctor.
    • SilentSeven
      • Feb 2014
      • 2184
      • Bellevue WA
      • 2004 Nautique 206
      The foam is precut for this pack out box. You then just cut out custom spaces for your tools/stuff. It's really cool....lots of YouTubes on how to do it.
      Sent from my Pixel 7 using Tapatalk
      Bellevue WA
      • MN Ryan
        • Aug 2020
        • 1390
        • Maple Grove, MN
        • 2007 SV-211 TE
        Oh, nice. Off to Home Depot!
        • bturner
          • Jun 2019
          • 1742
          • MI
          • 2016 200 Sport Nautique
          Is this the one you used?
          https://www.homedepot.com/p/RIDGID-2...551X3ZuE1HFZ6A
          • SilentSeven
            • Feb 2014
            • 2184
            • Bellevue WA
            • 2004 Nautique 206
            Yup. If you're using a prop bigger in diameter than a 422 (12.5"), ain't gonna fit.
            Bellevue WA
            • MN Ryan
              • Aug 2020
              • 1390
              • Maple Grove, MN
              • 2007 SV-211 TE
              I'll be the guy lugging a prop around Home Depot.
              • Scooter G
                • Jan 2022
                • 1470
                • On a Lake in Idaho
                • 2022 G23 ZZ8
                Very cool, I like it!
                I think I'm going to need a bigger box, lol.
                See it's funny because it's sort of a Jaws reference, and then I hear my Wife's voice in my head saying, "If you have to explain why it's funny, then it's not".
                I'll be quite now, I think the Winter is getting to me...
                • SilentSeven
                  • Feb 2014
                  • 2184
                  • Bellevue WA
                  • 2004 Nautique 206
                  FYI - it's hard to get pre-cut foam for the Rigid box. My HD didn't stock any foam inserts for any packout box. It was all orderable online.
                  I found two options. Order this DeWalt foam and cut it to fit (https://www.homedepot.com/p/DEWALT-T...8121/315040429) or order a pre-cut kit from these guys (https://www.kaizensource.com/?produc...kaizen-inserts). I went with option 1 as I didn't see option 2 until later.
                  I also trimmed the inside of my box a bit with an oscillating multitool. Not required but helpful to simplify the foam trimming. I'll add some pictures in a day or so.
                  Bellevue WA
                  • MN Ryan
                    • Aug 2020
                    • 1390
                    • Maple Grove, MN
                    • 2007 SV-211 TE
                    I took a trip to the HD. That Rigid box will not fit my prop, and I wasn't thrilled with their other options. I did a little sleuthing and found some people using the Apache weatherproof protective cases from Harbor Freight. It looks like the 4800 size will fit my props (I think I have a 14" and a 14.5"). It's a little pricier than that Rigid box, but you can usually use a coupon, and it comes with foam. It probably would not fit under the seat of a Pilot, though (not a criteria for me).
                    I think I will bring a prop along to the store to make sure it'll work.
                    https://www.harborfreight.com/4800-w...ack-64250.html
                    • SilentSeven
                      • Feb 2014
                      • 2184
                      • Bellevue WA
                      • 2004 Nautique 206
                      Cool. Looks like a good solution.
                      There's a lot of hard cases out there these days and as you noted - you just have to 'interview' a lot of them to find one that works for your size prop. What made my situation a little special was that I need a very space specific solution.
                      Bellevue WA
                      • Scooter G
                        • Jan 2022
                        • 1470
                        • 2022 G23 ZZ8
                        That Apache case looks pretty legit. Let us know if you go that direction for a 14.5" MN Ryan.
                        Click image for larger version  Name:	Apache.jpg Views:	0 Size:	115.7 KB ID:	673324
                        • SilentSeven
                          • Feb 2014
                          • 2184
                          • Bellevue WA
                          • 2004 Nautique 206
                          A few more detailed pics.....
                          Click image for larger version  Name:	PXL_20240126_152617646.jpg Views:	0 Size:	111.8 KB ID:	673428
                          303 bottle for size
                          Click image for larger version  Name:	PXL_20240126_152603245.jpg Views:	0 Size:	105.7 KB ID:	673429
                          Hacky home foam cut job. Trace the prop, cut with a sharp utility knife and a big kitchen knife for the deeper areas.Used a hole saw for the center section. Looks less than great with the prop out. But holds the prop really well.
                          You can 'mend' the loose edges with a little careful heat gun work.
                          Click image for larger version  Name:	PXL_20240126_152443802.jpg Views:	0 Size:	155.2 KB ID:	673430
                          Key field HF grade tools and a few bit repair parts in the side pocket. Have a few more emergency parts I plan to add to side pocket.
                          Click image for larger version  Name:	PXL_20240126_152507915.jpg Views:	0 Size:	301.3 KB ID:	673431
                          Bellevue WA
                          • MN Ryan
                            • Aug 2020
                            • 1390
                            • Maple Grove, MN
                            • 2007 SV-211 TE
                            Nice! I picked up the Apache case the other day but haven't gotten any further with the project.
                            • SilentSeven
                              • Feb 2014
                              • 2184
                              • Bellevue WA
                              • 2004 Nautique 206
                              Curious what type of foam they provide. The structured multi-layered poly foam is what you want. Stuff like this...lots of suppliers.
                              https://www.amazon.com/Fastcap-Kaize...007J2JJYK?th=1
                              Bellevue WA
