when i put my battery main power switch from all on to builge pump only, and cover the boat up. i still hear what sounds like, one of the fuel pumps running for just like 2 seconds, and it may recycle in about 10 minutes. maybe its somehting else, but it sounds like the fuel pump. is this proper. should i worry about anything.
i keep boat on a lift, about 3 feet above the water. i guess when i know i wont use it for more than a month, i'll pull the plug, drain it real good, put plug back in, and turn it all off.
