RE: Re: RE: Winterization necessary?
Up here in the Seattle/NW area, we can get a few days in the freezing point area to worry about, but not too often. With that being said, I know of at least a few people who have had frozen blocks and cracked exhaust manifolds for NOT winterizing. Even if I know it is going to be more than a few weeks before using my boat, I usually drain the manifolds, and sometimes the block too, even though I store mine in an attached insulated garage (i don't like the thought of rusty water sitting in the manifolds). I usually pull the impeller too just so that it doesn't sit in one position for too long, and gives me another excuse to rap my nuckles on the engine as I take it out! I second East-Tx-Skier, that it gives you a whole new perspective on your boat, AND, hopefully, gives you some education so that when you or a buddy needs some maintenance, you can handle it on your own...and save the shop hr/labor in the same right.
Maybe another topic, ...but what do all of you use to lube your impeller when you replace it? I am use a non-petrolleum base, but what do you guys use???
Todd
Todd
