September 13th, 2023 -- Boat: 1997 Ski Nautique 196 with GT40 engine
Description of Problem: Engine fires up immediately, accelerates like a rocket when pulling up a slalom skier, and runs like a champ. However, after approximately 15 minutes of slalom skiing at 32-33 mph, the engine cuts back abruptly but does not turn off. In 3-4 minutes with bilge blower on and engine at idle speed, it will accelerate strongly again and allow 5-6 minutes of additional slalom skiing before symptoms return. Temp gauge reads exactly where it should.
New low pressure fuel pump, new oil pressure switch, new/correct 160-degree thermostat, and fresh 15W40 Rotella oil and new Motorcraft FL1A oil filter had no effect.
New impeller. Water intake screen checked and is clear of any accumulated debris. Fuel: 90-octane Non-Ethanol.
Problem seems heat-related in some way.
Today, as an experiment, between slalom runs, we would turn off the engine and prop open the motor cover for several minutes before the next slalom run. The problem did NOT occur today using that procedure.
What is the underlying problem? I will be very grateful for advice!
