Hello to all.
We have a 1999 SN that we use for tow sports, mainly waterskiing. Love the boat. No issues with it for the last 8 years until this year, when a neighbor found it beached, with water inside up until the seats. We had just left cottage, so our mechanic picked up the boat and found the hull hugger muffler had cracked right in half. I suspect it is from age and from taking some friends tubing over waves earlier this year (boat is usually used in the ski course, on calm lake).
The part was spitting water in to the hull, and after enough water I suppose it was enough to sink it. The mechanic is looking for any other water ingress points.
I'd like to know if this part is salvageable, with fiberglass repair. I know it's a relatively big job, but if I were to sand and prep the whole can around, could I add enough material to reinforce it and avoid having to buy a replacement? We are in Canada, so any part likely would come from the USA and cost major $$.
If not, I have heard of people running straight pipes. I am not totally opposed to that, I have read there are some rubber hoses that can withstand high temps. Does anyone have any suggestions?
Finally, given that the boat was sitting in water likely up to the head of the motor, what needs to be done to ensure the boat is safe to run? Obviously oil change, and probably lubricate any moving parts, but other than drying the boat out, is there anything special we need to do? I can run some electrical tests on components.
Thanks in advance!
Thanks in advance!
