H6 engine Tic.
  • Sailfun
    • Dec 2016
    • 131
    • Lake Norman NC
    • 2018 Nautique G23 2022 Robalo 226
    H6 engine Tic.
    I am getting a loud ticking noise at idle when the engine is cold on my 2018 G23 with the H6 motor. I had the dealer mechanic look at it once while checking another issue and he felt it was a bit of belt noise and a non issue. It seems louder now and my warranty is ending soon. Anyone one have a similar issue?
  • Scooter G
    • Jan 2022
    • 1470
    • On a Lake in Idaho
    • 2022 G23 ZZ8
    In the old days, we used to use our ear to a long screw driver to isolate noises. Vibration was a little hard on the ear as you would probe around, but it would get you real close to the culprit. One day they came out with a probe specifically designed for narrowing it down, works great. Rattles and tics can be very deceiving to locate without some sort of probing device.
    https://www.amazon.com/Lisle-52500-Mechanics-Stethoscope/dp/B0002SQYSM/ref=sr_1_6?crid=1ZF8MNGU7V4RE&keywords=sound%2Bpro be&qid=1692565659&sprefix=sound%2Bprobe%2Caps%2C2 1 3&sr=8-6&th=1
    If it's getting more audible, I would narrow it down sooner than later, while still under warranty.
    I think you meant to say G23, yes?
    • Sailfun
      • Dec 2016
      • 131
      • Lake Norman NC
      Yes it is a G23. Fixed it. The strange thing is the noise is gone once the engine warms up. Going to take a look this evening to see if I can isolate it better but no luck last time I tried.
      • jpwhit
        • Aug 2016
        • 656
        • Cary, NC
        It super hard to diagnose engine noises without being able to hear it in person and use a mechanics stethoscope. But the most common tic type noise that goes away when warm, would be a valve train issue such an a sticking or failing lifter. If the boat is under warranty, then they should fix it. Don't accept an answer such as "it's not an issue" or don't worry "it's normal".
        • mpost
          • Jun 2007
          • 143
          • Monticello, MN.
          • 98 SN GT40
          I have used a long funnel to isolate some noises. large end over the ear and the small end will zero in on the area for electrical arcs and gastet leaks.
          1998 SN GT40
          84 2001 Ski Nautique (sold)
          Monticello MN.
          • SilentSeven
            • Feb 2014
            • 2184
            • Bellevue WA
            • 2004 Nautique 206
            I'd look closely for exhaust manifold leaks. They'll frequently sound like a tik tik and then change as the manifold gets to operating temp. Could also be lifters, etc, but I'd include an exhaust leak as a possibility.
            Bellevue WA
            • Sailfun
              • Dec 2016
              • 131
              • Lake Norman NC
              Thanks everyone for suggestions. The dealer is looking at the engine today. Will let you know the outcome.
              It was just the serpentine belt. Easy fix. Thankfully not a lifter.
