Jabsco Ballast Pumps…
  • Scooter G
    • Jan 2022
    • 1416
    • On a Lake in Idaho
    • 2022 G23 ZZ8
    Love me the kitchen table projects with a baby bumbler, ha, good job man!
    • ScooterMcgavin
      • 1542
      • 2014 SAN 210 TE
      Nice work man!
      1989 Sport Nautique
      • MN Ryan
        • Aug 2020
        • 1368
        • Maple Grove, MN
        • 2007 SV-211 TE
        Nice!
        • Boats Bros
          • Mar 2023
          • 146
          • Texas
          • 2009 SANTE 210 Full Throttle 2003 SANTE 210
          Thanks y’all, maybe one day the babies will appreciate being able to wakeboard behind this boat.
          2009 Super Air Nautique 210 Team ZR-409
          2003 Super Air Nautique 210 Team Edition
          1994 Sport Nautique
          • jhiestand
            • 786
            • Columbus, Ohio
            • 08 Super Air 210
            Late to the party here and sounds like this has been resolved, but our 08 is an SE and I found that once the ballast gauges hit "E"mpty the power is cut to the pump(s). Apparently not a player in this instance, but took me a while to figure that out when I couldn't get ours to fire up a while back.
            '08 Super Air Nautique 210
            • Jeffers
              • Jul 2023
              • 1
              • Toronto Ontario
              • 2014 Nautique G21 1997 Air Nautique
              #21
              jpwhit - you're a remarkable source of insights! I just found my 3 pumps seized - likely lack of use in last 2 years. Jabsco 18670-9407 and 2 Jabsco 18670-6127. Is there a quick way to pull it apart and try penetrating oil/motor oil to unseize it? or are there rebuild kits?
              Worse case, I will order new but as I am in Canada, it is harder to get parts at reasonable prices
              thx for your insights
              • jpwhit
                • Aug 2016
                • 641
                • Cary, NC
                #22
                I've never seen a rebuild kit with new bearings, but I can't say I've really searched for them either. Yes, you can take them apart and clean up and lube the bearings. I don't think I'd use penetrating oil on them unless I couldn't get the bearings off the motor shaft without it. The pump manufacturers recommend mounting the pumps with the impeller on the bottom facing down, but it typically makes it harder to change the impellers. That's so the water in the pump head won't drain towards the motor bearings if the seals leak any. Most boat makers don't mount them the recommended orientation.
