Another update.
Just had to find a better wrench for the spark plug socket fitment, all good there. Re-pulled them to make sure I didn't mess anything up the first time, and also to add some anti-seize (not that I expected it to improve the situation).
Took out the gauges I added, and used an inline spark tester when trying to start up again. Sparking looks fine as far I know. The lightbulb in the tester lit up, and at a regular interval. When pulling the old, and re-pulling the new spark plugs, they had gas on them. I think this means my gas supply is fine.
I noticed the ground connection for the engine block, to the frame, was very dirty. I cleaned that up (maybe not as best as I could though).
So to this point, the battery is good and appears my gauge install is not the culprit. It seems like I am getting fuel and spark, which really just leaves the air component. Could it also be possible that the computer went bad?
For the record, and if this helps, the motor does have pretty high hours. Over 1000.
