Please help!
I have a 2004 210 with zr6 engine. The water pump isn’t working. I tried replacing the Impellar and cleaned strainer. I also disconnected the hose going into the strainer from bottom of boat and used water hose to remove any debris out the bottom of boat. Hooked it all back up and I see water going into the strainer when I initially start the boat but then it seems to stop as I don’t see water swirling around as i normally would. Any advice before giving up on the weekend and taking to dealer Monday??
Thanks
Thanks
