Hey y'all - I've read a few seemingly conflicting threads regarding adjusted props and looking to see if there is any consensus. The prop on the boat I'm getting needs to be replaced so I'm wondering if I can preemptively make a change that will improve GPH and noise to suit our needs. The boat is 2017 G23 with H6 motor. We're probably going to skew more 50/50 surfing/cruising and floating for the first year of ownership, nothing over stock ballast and typically a small crew. Is there a prop that I should look at that will increase top speed, reduce noise, and increase fuel efficiency knowing we aren't lugging around huge crew and super weighted down G?
I heard the 3087 tossed around a bit, and on ACME site they have 3043 as an option. Any thoughts?
