I did quite a bit of searching and my apologies if there is a thread that answers this. I’m going to winterize my 2019 G23 H6 for the first time. The dealer normally does it but the cost is now just crazy (see other thread). I’ve looked for videos on YT and haven’t actually found a great one yet. Any tips on that are welcome.
Anyway, draining the thing appears straightforward but then flushing it with antifreeze is a different level of drama. Hose attachments and fake lakes etc. so my question is, how cold does it have to before you run the risk of a problem?
I live in Georgia. The air temperature doesn’t go below 32 almost ever. The boat is on a lift over the lake which certainly has never frozen so that would add a bit of temperature vs the boat being on a driveway for example.
So ‘dry block’ vs running antifreeze. And of course if the forecast becomes a freak say 20 degrees for a week then I could use a block heater / drop it in the water and run it every day / then go to the trouble of filling it with antifreeze.
I’m in two minds and would welcome members advice..
thanks
thanks
