Deoxit D5 for cleaning PME Relay terminals?
  • billywro
    • Mar 2011
    • 72
    • Lake Martin
    • Birmingham, AL
    • 1994 Ski Nautique
    Does anyone have any experience using DEOXIT D5 for cleaning up electrical connections?
    This socket receives the 4-prong PME Relay (new relay purchased), and I am wondering if this is salvageable.
  • Skidave
    • May 2005
    • 697
    • York, PA
    Yikes, that oxidation has already taken any plating off the metal connectors. I would recommend a small wire brush and some alcohol to clean. Dry it and see how it looks. If it cleans up a bit, then I would pit some dielectric grease on the connectors and then connect your relay.
    All that said...you should replace the connectors inside the housing. Sourcing them is going to be a pain.
    • ScooterMcgavin
      • 1551
      • 2014 SAN 210 TE
      These terminal cleaning kits are pretty nice, Pricey but effective
      https://www.amazon.com/Innovative-Pr...2-8997e41410bb
      1989 Sport Nautique
      • jpwhit
        • Aug 2016
        • 642
        • Cary, NC
        That's really beyond saving. With the plating on the contacts gone, even if you get it clean they will corrode and it'll cause issues over time. Replace the contacts.
        • billywro
          • Mar 2011
          • 72
          • Lake Martin
          • Birmingham, AL
          • 1994 Ski Nautique
          Thanks for the feedback, I like to rehab/reuse when possible. I did find all the required pieces to build a replacement thru custom connector kits.com if I have to go that route. I’d have to buy a crimping tool, but I am sure I can find another use for it down the road.
          • billywro
            • Mar 2011
            • 72
            • Lake Martin
            • Birmingham, AL
            • 1994 Ski Nautique
            I thought the crimping tool was going to be > $100, but turned out to be $40. All in to build a new socket is only $45. Probably never would have started this post if I had known that, but thanks to all for your thoughts.
            • ScooterMcgavin
              • 1551
              • 2014 SAN 210 TE
              Nice!
              1989 Sport Nautique
              • Rednucleus
                • Jul 2022
                • 232
                • WA
                Pics of your new fancy socket when done please!! I love to keep stuff in use forever, but that socket is toasted!
                • billywro
                  • Mar 2011
                  • 72
                  • Lake Martin
                  • Birmingham, AL
                  • 1994 Ski Nautique
                  Have the parts on the way to rebuild the socket, but used the Deoxit as a temporary measure so I could test the new PME Relay. Cleaned it up pretty well; at least good enough to get the boat running. Will post a pic of the new socket when done.
Name:	Annotation 2022-10-18 150426.jpg
                  • ScooterMcgavin
                    • 1551
                    • 2014 SAN 210 TE
                    Seems like it cleaned up pretty good, That stuff seems to work well
                    1989 Sport Nautique
                    • Scooter G
                      • Jan 2022
                      • 1417
                      • On a Lake in Idaho
                      • 2022 G23 ZZ8
                      That was an amazing transformation, I'm impressed!
                      • billywro
                        • Mar 2011
                        • 72
                        • Lake Martin
                        • Birmingham, AL
                        • 1994 Ski Nautique
                        I am not ashamed to say I "geeked out" on this project. Enjoyed adding a new trick to the bag.
                        1 - Crimper works great. Silicone seals are also crimped.
                        Terminals snap/lock into place easily. Green plug for unused slot.
                        Back plate snaps in a seals even more.
                        Ready to be installed with some heat-shrink solder connectors.
                        • jpwhit
                          • Aug 2016
                          • 642
                          • Cary, NC
                          Thumbs up on the "Ready to be installed with some heat-shrink solder connectors." That's the only way to repair wiring IMO. I never use any kind of crimp connectors for wire to wire connections on stranded low voltage wiring. Overall an impressive "if it's worth doing, do it right" repair. It'll pay dividends in downstream reliability.
                          • Scooter G
                            • Jan 2022
                            • 1417
                            • 2022 G23 ZZ8
                            Nice work billywro!
                            Agreed with jpwhit, electrical & moisture are arch enemies.
