Temperature Sender Replacement GT40 (on waterpump housing)
  • FMSKI
    • Aug 2010
    • 241
    • Sproat Lake
    • 07 SV211 Ex330 Ski 'n Surf Sold (Ski 200, TSC1, 2001)
    So I have a bad sender and trying to get the thing out with a open-end wrench, no way it will budge. Tried penetrant, torched it (water on backside, so won't get that hot).
    At risk of rounding I have stopped there and just zapped-tied a new sender to the old for now.
    So the T-stat housing and base would need to come off to get a proper socket on it. Is the gasketing PCM only? Any other tips?
  • mpost
    • Jun 2007
    • 143
    • Monticello, MN.
    • 98 SN GT40
    Maybe one of these would help.
    Click image for larger version  Name:	flare nut wrench.png Views:	0 Size:	32.7 KB ID:	657149
    1998 SN GT40
    84 2001 Ski Nautique (sold)
    Monticello MN.
    • FMSKI
      • Aug 2010
      • 241
      • Sproat Lake
      Thanks that's a good idea. I have a 10/11mm wrench like this. Didn't know they were made for larger sizes. Called a flare nut wrench.
      I actually tried two 19mm wrenches in sync but still couldn't break it loose.
      • FMSKI
        • Aug 2010
        • 241
        • Sproat Lake
        After getting the flare wrench and grinding it down, won't go. Then got my slimmest ring-end wrench, got a good hold of it and managed to bump it loose. It was like a wheel nut torque. Well then the fun began.
        1. Temperature gauge went DOWN as I drove around the lake.
        2. Opened the T-stat housing to find it had split in 1/2, so was basically open flow all the time.. didn't know cause my sender was bad.
        3. Installed new t-stat I got from a buddy with a ~ incorrect gasket (punched new bolt holes, it worked).
        4. Temp gauge then went to 200 or so, because the sender I got locally here is the part for a '95 Econoline van
        5. Ordered parts from NP!!
        • shag
          • 2217
          PB blaster usually works for me... Might have to let it set overnight.... I actually free'd up a locked up motor with PB Blaster one time lol
