So I've been digging into a boat I purchased a year or two ago because I had to pull the v-drive, and I found a depth finder transducer that I didn't realize was right beneath the v-drive. I could trace the sending wire back to the dash too, but I don't have a gauge. So first question, what are the odds that transducer still works? I think my odds are good, but if it was put in back in the early 2000s as I suspect, then it should probably only read to 200 feet right? And if that's the case, am I correct in assuming that if I buy a 600 foot gauge that my reading will always be 1/3 of the actual depth? Also I should clarify, I definitely don't want to replace the transducer, I've put them in before, and that was when I didn't have to deal with getting an old one out. Needless to say it wasn't fun and I'd rather not, especially since it's located directly beneath the v-drive. While on this topic, I think I'll have to splice wires to get the new gauge to work if I go that route, so the wires should just be power in and signal out right?
Per the manual (chapter 1.1), a depth finder was optional. It seems more likely that it came from the factory with the transducer installed than that someone installed it later.
2000 SAN manual: https://www.planetnautique.com/Corre.../2000SSSAN.pdf
Haha well I’m actually on the Colorado river usually, so about 2-20ft deep, only ever see past 200 feet when I make it up to powell. Anyway I’m not worried about reading super deep, I just thought I should match a 200ft gauge to a 200ft transducer so that when it reads the signal, they’re on the same scale and the reading will be correct.
I would not go to the expense of buying a gauge and expecting that 22-year-old transducer to work. Those transducers are known to not be that reliable. New ones are only about $80 though.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
In case anyone was wondering, I did get another transducer, the only real difficult part was popping the old one off. Swinging a 3lb hammer in the bilge beneath the v-drive and prop shaft and between the transmission and thru-hull intakes definitely was not easy, but I found the the sanding and prep was not bad after taking the old one out. It left a pretty smooth surface on the fiberglass. The only thing I will say I goofed on is the new epoxy, I put beads on the hill and transducer then smushed them together. I think that’s a good way to end up with air bubbles, so we’ll see what happens when I drop it in the water this week. Thanks for the recommendation though Jeff!
