Hi
94 Sport with a 5.8 Pro-Boss EFI.
Any recommendations for an alternator upgrade? I know some of you have purchased some very very nice units. I am looking for something that gives the best cost/benefit and ease of installation. I am running quite a bit of juice with 3 amps, 4 55w lights up top (Which do get used), ballast pumps, etc. Thinking around 80amps? Maybe 100amps.
Should I investigate rebuilding the stock alternator? Is it possible to increase it to 80amps?
I know I will need to replace the main wire running from the alternator to the battery. Anything else to keep in mind? I am currently showing 13.5 volts on the back of the alternator with the engine running. It does not flux when reving in neutral. I am hoping the new alternator will give me 14.4v right? I am also hoping the new alternator will charge batteries faster and will be able to help handle the voltage drops caused by the stereo (Also installing a 1 farad capacitor to help with this)
How long should it take a qualified mechanic to replace the alternator?
Thanks
Thanks
