This is my first boat with a heater, We took the boat out this past weekend and when I got back in from a set I turned the heater on to warm up and it was…. warm just not blowing real hot, so I figured I’d ask here. Is there anything I can check or is this normal? There isn’t many settings in the link but on/off.
2014 210 Heater question
1989 Sport NautiqueTags: None
The faster the engine is turning, the hotter the air will be. At idle, there won't be a ton of heat.Please do not PM me directly asking for advice on how to repair your boat. While I would love to help everyone, I simply do not have time to respond to all of the inquiries. Please post your questions on the forum, so that all of our members have a chance to answer.
Ok, I wasn’t sure if the just having the engine up to operating temp would produce sufficient heat or if the Rpm’s needed to be higher. Like I said just got in from a surf set and started boat back up but yeah we were just idling around or low Rpm’s at that time, not going 20mph or cruising the lake, thank you2009 Super Air Nautique 210 TE
1989 Sport Nautique
Yeah, the hot water needs to be pushed through the heater, and that is only really happening at higher speeds.
There is a low-speed mod that can be done to provide additional heat at idle. I believe it adds a pump to the lines that run to the heater. You can probably find that by searching.Please do not PM me directly asking for advice on how to repair your boat. While I would love to help everyone, I simply do not have time to respond to all of the inquiries. Please post your questions on the forum, so that all of our members have a chance to answer.
I've noticed the same with mine (it's an '07, but I'd imagine they work the same). Also, the alternator doesn't kick out enough juice to run all the ballast pumps and the heater fan at the same time, muy to my daughter's disappointment.
Thanks Guys, makes sense2009 Super Air Nautique 210 TE
1989 Sport Nautique
this guy, though some try cheaper amazon ones with mixed longevity results: https://www.hodgesmarine.com/joh10-2...hoCn34QAvD_BwEOriginally posted by NautiqueJeff View PostThere is a low-speed mod that can be done to provide additional heat at idle. I believe it adds a pump to the lines that run to the heater. You can probably find that by searching.
A simple inline pump to circulate the water while at idle does wonders! I did that a few years ago and it works great! Just don't forget to turn it off when not needed. I just put a red LED switch down by where the ignition kill switch is on my 08 SAN.
Ok I ordered the pump, thank you guys for the info really appreciate it.2009 Super Air Nautique 210 TE
1989 Sport Nautique
Next question… is there a way to have this pump turn on and off with heater? So I don’t have to run a separate switch or forget to turn it off.2009 Super Air Nautique 210 TE
1989 Sport Nautique
You should be able to wire the pump right into the heater wiring. I wouldn't think that would be too difficult.Please do not PM me directly asking for advice on how to repair your boat. While I would love to help everyone, I simply do not have time to respond to all of the inquiries. Please post your questions on the forum, so that all of our members have a chance to answer.
I don't know of this is still applicable. But it might help as you may want to consider a low idle wye as compared to a circulation pump.
2008 210 heater install - PlanetNautique Forums
Quote removed by Admin for not following the Guidelines for Quoting Previous Posts in a Thread.
It is an option, but I just have never had great luck with those Y's. The pump is a pretty easy install - just place inline and wire it up - boom, heat at idle... Maybe others have had good luck with them...
