Swim Grid Modification
  • Pacer1
    • Jul 2021
    • 16
    • British Columbia, Canada
    • 2003 206 Air TE
    Hello Everyone...I have a question has anyone ever modified their swim grid(platform) teak or fibreglass before? We finally got our dream boat a 206 (needed the seating for extended family) that with the swim grid is 4 inches to long for our lake property association dock rules---I have tried EVERYTHING to get the rules modified but won't happen so I need to either trim off a few inches off the platform or hinge it up when it is parked......Has anyone done or know of if these option are a possibility?? I have the fibreglass platform on the boat as seen below Click image for larger version
Name:	Screen Shot 2022-02-13 at 7.42.33 AM.png
ID:	648027 Click image for larger version
    Thanks Everyone for the input..
    Jon
  • zigs
    • May 2007
    • 102
    • ND
    • 2018 G21 2004 196
    Is the teak platform smaller? Unless it is just the angle of the pic my 04 196 has a teak platform, and it looks shorter than that. Not sure if it would be four inches though. Mine is at the lake house otherwise I would take a quick measurement for comparison.
    • charlesml3
      • Jan 2008
      • 2479
      • Lake Gaston, NC
      • 2022 G23
      Just take it off. It's on brackets with lock pins on either side. It takes two people but it's quick. I used to have to do this when I parked mine in the garage in order to get the garage door closed.
      -Charles
      • Pacer1
        • Jul 2021
        • 16
        • 2003 206 Air TE
        I wonder if the teak platform is smaller this fibreglass one is 24 inches ....I can't take it off every time I dock that would be extremely difficult
        • MN Ryan
          • Aug 2020
          • 1370
          • Maple Grove, MN
          • 2007 SV-211 TE
          Is someone actually going to measure it? I would just leave it be until it becomes a problem.
          Sent from my SM-G970U using Tapatalk
          • Pacer1
            • Jul 2021
            • 16
            • 2003 206 Air TE
            Ryan--Sadly yes there will be someone to measure for compliance
            • ScooterMcgavin
              • 1550
              • 2014 SAN 210 TE
              http://www.teakmarinewoodwork.com/sw..._platforms.htm
              You could have one custom made for your boat any size you need if it came down to it.
              1989 Sport Nautique
              • MN Ryan
                • Aug 2020
                • 1370
                • Maple Grove, MN
                • 2007 SV-211 TE
                Wow, that's ridiculous. I'm glad I don't have to deal with that BS.
                Could you just pull it off, have them measure it, and then put it back on after your "inspection"?
                • SilentSeven
                  • Feb 2014
                  • 2051
                  • Bellevue WA
                  • 2004 Nautique 206
                  I have a 2004 206 with a factory teak platform..that's conveniently off the boat for refinishing
                  Measured at the middle of the platform (fore-aft) from the transom to the rear edge of the platform it's 23 inches deep.
                  Click image for larger version  Name:	PXL_20220213_231438814.jpg Views:	0 Size:	82.7 KB ID:	648044
                  See that last half moon shaped board....? The board adds 5"...remove that and you're good to go. I bet if you were clever, you could even engineer a way to slide out/slide in and pin that last section. Slide out at the dock....put back in for use.
                  Bellevue WA
                  • Pacer1
                    • Jul 2021
                    • 16
                    • 2003 206 Air TE
                    hmm that is a thought...I like the possible custom order but I Dont like the cad/US exchange rate high now I also would not be opposed to a teak deck where I could get the last few inches off. Thanks for the help guys
                    • bturner
                      • Jun 2019
                      • 1685
                      • MI
                      • 2016 200 Sport Nautique
                      The new wood platform seems to be the answer albeit an expensive one. You could try to get this done locally but I've found (we have a cottage outside Windsor on Lake Erie that we haven't seen in 2 years) that after all the taxes you'll pay on most custom items like this, it'll still be cheaper even with the exchange rate coming from the states. Beats the heck out of cutting up a fiberglass platform then trying to patch in or mold a new profile.
                      Either option is going to be expensive but it's better than not being able to use the boat.
                      • MN Ryan
                        • Aug 2020
                        • 1370
                        • Maple Grove, MN
                        • 2007 SV-211 TE
                        If you're at all handy, something like what SilentSeven posted shouldn't be too bad to build, especially if you can get someone to post a few pics of the underside and some measurements. You could basically copy the design but exclude two boards to make it smaller. Heck, if I were closer to you, I'd help you out.
                        • srock
                          • Oct 2008
                          • 1094
                          Build it and if you don't have the skills find a carpenter, cabinet maker, trim installer. They can whip out a platform to fit your brackets in less than a day. Another option is post a wanted to buy or trade. I bet someone would like your fiberglass over their teak. If you want to spend the money search for someone who can make it from fiberglass.
                          • srock
                            • Oct 2008
                            • 1094
                            https://www.facebook.com/groups/2145...0062445584253/
                            Here you go. Funny how this stuff pops up
                            • SilentSeven
                              • Feb 2014
                              • 2051
                              • Bellevue WA
                              • 2004 Nautique 206
                              Linky no workie.
                              Bellevue WA
