V drive water drain, 2015, PCM343
  • relake
    • May 2016
    • 6
    • South Carolina
    • 2015 SAN210
    Anyone have any tips for breaking loose the 1/2” plug in the v drive? Squirted with penetrant, using a 1/2” socket drive and it won’t budge. Thanks!
  • scottb7
    • Aug 2011
    • 2198
    • Carson City, Nevada
    I had a stuck one in one of my boats. I realized though that since I sucked in rv anti-freeze thru the system there was no way it could have water in it.
    That being said, the only advice I would have would be to get some extensions and maybe get to a spot where you can get a breaker bar, and/or a piece of pipe over the ratchet.
    • XBIGPUN66
      • Oct 2012
      • 473
      • Lake Mendota
      • WI
      I would try some heating
      Ian S
      • relake
        • May 2016
        • 6
        • South Carolina
        • 2015 SAN210
        Ian, I do have a heat gun, I’ll give it a try…I’ll see if I can dig up a pipe to use as leverage as well
        • bturner
          • Jun 2019
          • 1692
          • MI
          • 2016 200 Sport Nautique
          I used a 12" drive, 3' long breaker with I believe a 3" extension on it to clear the end of the vDrive. The hardest part was supporting the bottom of the breaker to keep it from moving. Mine started to move after about 3 bumps. Another thought depending on room might be a 1/2" universal joint with an extension and a impact gun.
          • relake
            • May 2016
            • 6
            • South Carolina
            • 2015 SAN210
            I cannot get it to budge at all, heated it, etc….any idea how much water is held in there?
            • SilentSeven
              • Feb 2014
              • 2068
              • Bellevue WA
              • 2004 Nautique 206
              Soak it in PB Blaster? Rarely do I give kudos to a product...but that stuff works.
              Maybe this will help....https://www.youtube.com/watch?v=hxFA08qRSoY
              Bellevue WA
              • bturner
                • Jun 2019
                • 1692
                • MI
                Unfortunately if yours is like mine, tons. I was shocked. If you absolutely can't get it out I would consider draining everything else and go to the "running the antifreeze through the block" method of pickling the engine. You basically run the engine on a hose until hot then swap out water for antifreeze in a bucket and run until you see a good flow of antifreeze coming out the exhaust. Not my favorite but there are a lot of people that swear by it.
                • hal2814
                  • Jun 2016
                  • 548
                  • Ft Worth, TX
                  The first year I had my boat it was stubborn so I used a breaker bar and extension. I propped the extension up on a block to help keep it stable. I did hit it with PB blaster every few hours starting a day or so before.
                  • nyryan2001
                    • Mar 2013
                    • 1993
                    • Lake Anna
                    18v impact full send!
                    just 100% verify you have it in reverse!
                    2019 G23 450
                    2014 G23 550
                    2013 G23 450
                    2011 Malibu Wakesetter 247
                    2007 Yamaha AR210
