Has anyone ever done the GPS upgrade to their PerfectPass on 2006 - 2008 with the Nautique gateway box? I have a couple of questions and have run across one problem.
Questions:
1. Where did you mount the Stargazer master module? They say under the dash on the right side, but I do not want to screw into something I am not supposed to.
2. Where did you mount the GPS antenna? PerfectPass said you could mount it under the fiberglass just curious for recommendations.
Problem:
Everything is plugged up properly, and the PerfectPass unit works and acquires a GPS signal. However, when I turn on the dash lights, no gauges light up, and the fuel gauge goes to empty. However, when I unplug the StarGazer and plug back in the main harness into the gateway box - all gauges light up.
Questions:
Problem:
