I've had this phantom issue that multiple marinas can't recreate (and fix). In calm water, the boat runs completely fine at any speed. In some light chop, at speeds above about 15 mph, the engine will suddenly die with no error messages, as if the emergency lanyard is removed. At first, I thought it was related to the manual and metal SurfGate handle coming into contact with a wire behind the throttle/emergency kill switch since I could get it to die when I shifted it to the "3" position where the metal part was closest to the wires. I took the subwoofer out to reposition some of the wires away from the metal, but it continues to die. Also, the wires seem to be securely connected to the emergency kill switch.
I've checked the emergency lanyard and kill switch many times, which is correctly attached.
Has anyone experienced something similar? Both Nautique marinas were not able to recreate the problem, and therefore couldn't diagnose the issue. I'm guessing they lake tested in calmer water.
Any thoughts or tips? Very frustrating as we can't really trust the boat to do anything in terms of water sports. Thanks!
