I have a 2002 Air. I noticed this weekend that my transmission was slipping. If I tryed to get the boat on plane it would rev up like it was going into neutral I could only idle. I first noticed that the boat would not go into forward gear with the positive feel it has always had. Example you would click it in to forward and it would take a second before you would hear the prop spin or feel it. Reverse was normal as soon as you would put it in reverse it would start spinning right away. I checked the transmission fluid and it was normal. I also tryed disconnecting the cable at the transmission and putting the transmission in gear by hand it still didnt fix the problem
I dropped the boat off at the service center to get it fixed. Wanted to see if anyone had heard of this before?
