I have a 2020 GS22. The belly ballast is not filling (although is says it is on the screen) when the other to bags are filling. Having done a bit of research, I believe the issue to be with the sensor. I am taking the boat out this week and was going to try and disconnect the sensor so that I can fill the bag as needed. I've looked in several places for the sensor but can not locate it. Does anyone have an idea where the sensor is located, and what the easiest access to it is? Any help would be appreciated.
Thank you
Thank you
