02 Super Sport - 330 Excalibur 5.7 - Just recently changed impeller (newbie here) and noticed there is a decent drip off of the pump and it seems that more water is collecting in the bilge than before. Boat is running fine so far. I've Been reading and see this is common and might be an issue with the newer gaskets included with the impeller? I see some people have had luck with thicker gasket paper from auto parts store or liquid gasket or both? What would you guys do first to troubleshoot? Also, trying to figure out which water pump I have: Serpentine/Crank/Belt? It is connected to a belt and my boat has 2 belts? Located Rear Port side. Thanks!
Final question: My strainer has some cloudiness to it, almost looks like mineral build up (to me) - I've tried to unscrew it to investigate/clean but its too tight and I feel like I'm going to break it if I force it. Boat was purchased from a guy who barely used it for years and kept it in heated garage so never winterized it. Could be from water sitting in there for months. Anyone seen this?
