Can someone offer some advice about restoring the trim on a 2002 196. There are several panels of push buttons on either side of the wheel. The trim around the panels looks horrible. Like the varnish or shellac or whatever is yellowing, becoming discolored and peeling off. I could use a dremel to remove this narrow trim??
Should I just replace the whole panel assembly...is it even available. The rubber buttons don't look that bad, but the trim surrounding them needs to be repainted with a fine brush or somehow restored.
