A friend of mine bought a PCM# RK107025A conversion kit from Nautique Parts. He asked if I could install it for him . It seemed pretty straight forward so I said yes . I thought the kit was made for this conversion but it is more like a bunch of cobbled up parts that are close but not quite a perfect fit to his engine. The directions are a joke hand written and very generic. He also supplied me with a copy of a wiring diagram for this kit off the forum . Using both and the knowledge I have from 40 years of working on 351 PCM engines I got it done . The boat runs great but I have a couple quirks . First the volt gauge reads low around 12 volts but 14.2 at the battery. Second the tach reads low about 4-500 RPMS it increases with the throttle but is off. The owner thought he has a ground issue in the dash that causes the volts to read low but the tach was reading fine before the conversion . Has anyone installed this kit and had similar issues? Any ideas where to start the gray wire is securely attached to the - side of the coil ,
I bought the RH version of that kit. At one point it was the cheapest way to get a RH Mallory distributor. I never had to do a full install but I have seen the kit firsthand. It is a cobbled together kit with little instruction. As far as voltage I think you’re going to have to trace back to see where the issue is. I’d be especially suspicious of parasitic drain through a ground. Not sure what year or model you’re working with but I’m pretty sure all dash setups for the protec years are a daisy chained mess.
As far as RPM, are you sure it’s wrong? You changed the method of spark distribution and some of the timing characteristics. That can affect the RPMs.
After thinking about it I wonder if the tach is set to 4 cyl instead of 8 . The ProTech DI system fires both the compression and exhaust of two cylinder mates . That is why there are 4 coils on a V8 system. I will check this weekend . Has anyone else installed this kit and had this trouble? I am working on a 93 Sport 351 w.
