I have a 1990 SN with 351 W and would like a 4 blade prop to perform similar to the standard 3 blade, but better! Suggestions?
You can search on the pros and cons of 3 vs 4 bladed props. Lots of information here and on ballofspay.com on that topic.
Wakemakers.com has a nice prop selection tool you can use to pick choices for your boat.
https://www.wakemakers.com/props/2004 206 Air Nautique Limited - Black with Vapor Blue (family style)
Bellevue WA
You might also try an OJ SkiPro. You'd need to call them to find the best fit, but they can set you up right.
https://www.ojprops.com/products/skipro/Please do not PM me directly asking for advice on how to repair your boat. While I would love to help everyone, I simply do not have time to respond to all of the inquiries. Please post your questions on the forum, so that all of our members have a chance to answer.
Assuming that you have a standard LH rotation engine and PCM 1.23:1 transmission, then I would lean toward the ACME 654. If you are a RH engine with 1:1 Velvet, then I would call ACME.
JQLast edited by Jonny Quest; 05-26-2021, 09:37 AM.
