Pulled my 17 G23 out of storage yesterday installed all the plugs, batteries, Bimini etc. Was going to take it to the lake today but it doesn't start. It will just spin over and over. Checked all the fuses, fuel pump is kicking on, lanyard is on correctly. Just bought the boat last year and there was no code to start it could it be since the batteries were out for 6 months I need a code or would it just not turn over? Not sure what else to check.
Yep it's full. I've cycled it numerous times and never tried to start.Originally posted by nohlan_4 View PostFuel in the boat? Try cycling the key a couple times to prime the pump then go for a start. Pump might have lost prime. Does it try to fire at all?
Got it figured out thanks! Drained the FCC and Fuel/Water separator as the manual says then cycled it a several times and it eventually started up. Its a coastal edition so Im going to hook the hose to it this afternoon and let it run for a few min.
