Desperately looking for some advice or someone to convince me that dropping $650 on a new raw water pump will finally fix my issues with my 2006 210.
Put the boat in the water, idled for a bit at the access, made the 2 minute drive to the lift and left it for the week, no issues. Took it out to ride and engine temp was sitting around 180-190 at idle but would drop to 160 with increase in RPMs. Finally started climbing to 200 so took it back to the lift. Took the impeller out, scarred but no fins were missing. Threw in my backup, never primed and got torched once I realized engine temp was gonna pass 160 but again, no fins missing. Have since been trouble shooting with a brand new impeller from nautiqueparts and local dealer. Unable to get raw water pump to pump water. Replacement thermostat already as a Hail Mary. Able to manually dump water through every major part of the cooling system. Boat runs fine with a hose and fake-a-lake, immediately disconnect hose and put inlet into bucket of water and unable to suck water. Checked all hoses, changed o-ring and bolt washers on raw water pump. Can even put inlet hose directly to inlet of water pump and disconnect outlet hose from pump and still no dice. Also no leaks when the system is filled with water. Ordered my last new impeller from nautiqueparts and plan to put sealant on the housing and see if it can suck from the bucket, but its such a simple mechanism it has to be a simple answer before buying an all new pump or taking it to a shop. 1000 hours on the boat but still seems too early for the inside to wear. Still smooth, no imperfections. No clogs/buildup anywhere (have taken every possible hose apart and inspected from the water strainer to the manifolds.
