I'm trying to figure out what is going on with my 2009 SANTE210. It has a PCM 343. Voltage gauge is showing <12V. I replaced both batteries that were old although I knew that wasn't the problem. I pulled the alternator (100 A, ra097009) and I replaced the voltage regulator (D2295) on it figuring that was the issue. The alternator itself looks great, but I can't find anyone around here to test it. The voltage regulator did not fix the problem when I just re-installed the alternator.
Is there anything else this could be, or am I for sure looking at a new alternator? I didnt see any other wiring, relay, or fuse that could cause this. Confirmed voltage at output of alternator is ~12V. Set point should be around 14.7
Anything I could be missing?
