I have a 2010 Nautique 226, battery 1 was replaced today. Nautique dealer said battery was dead. Upon changing it I still only get a brief click. Connections on terminal look good. Ground is tight on the boat. Please help? I’m selling and wanting to give this to the new owner properly.
you shouldn't need to pull anything out. If you have 2 batteries, you should have a battery switch. I don't know where it is on your boat, but I would check under the rear seats, or under the observers seat. Should be red, and have a dial you can turn.
Where is the ground block under the dash? The ground to the motor is tight.Last edited by Keith84navy; 03-26-2021, 11:53 AM.
