I am looking at buying a 2005 206 and apparently some of the gauges are out. There isn't much information in the ad except that they are not working. I am trying to figure out if there is a way that a shop can figure out how many hours are actually on the engine. I'm getting mixed information. One place said that yes, you can figure out how many hours are on an engine if you hook it up to a reader. The other place said that it depends on the type of engine that is in the boat. (They said the two possibilities would be the XCaliber or the GT40.). The second place said you could tell the hours on the XCaliber, but not the GT40.
I'm also trying to figure out if this is something most boat service departments would have. The Nautique dealer closer to where I would be buying the boat (Nashville) doesn't do that any more.
Finally, I'm trying to figure out if that is something that is portable. In other words, could a tech take the device to the boat and figure out how many hours or would I have to arrange for the boat to be brought in?
The ad says the boat has about 750 hours on it. If it's close to that, I'm fine. If it's significantly more than that, I'd be concerned. Thoughts?
Joking aside, yes it will correct the problem with the poorly design gateway box by replacing everything. Gauges do go bad so nothing is permanent but as far as addressing the issue then yes this is the standard for repairing the gauges.
