I have a 1990 "Ski nautique" boat
Dear all,
I have not use my boat for 3 fuul week due to bad weather condition and heavy rain. Last month I change the start relay dur to startup trouble. After those change my boat was starting up very fine.
Now that wether gets better, I went to my boat yesterday and try to start it. I turn the key and notice that my engine was able to launch with enough power. Then I turn off the key and mysteriously my engine continu to try to be launch in the similar way I would turn the ky again. So I switch off the ignition button and still the engine continue to start to lanuch. The final solution was to disconnect the batrery. But then with ignition oFf and key in my pocket as soon as I reconnect the batterie, engine stry to start to launch..
What might have casue this, could it be a realay contact which is stuck in ON position due to humidiy because of so long bad weather.?
Thnaks for your help and ideas
regards
serge
Dear all,
regards
serge
