V-Drive fluid change 2007 SAN 236 TE
  • Sinclr12
    • Sep 2020
    • 2
    • New York
    • 2007 - SAN 236 TE
    First post, and hoping someone can explain my confusion, checking my V-Drive fluids and need to add more, everything in the manual tells me it’s Mobiltrans SHC 50 and the fluids are yellow so I believe this to be right. However, the top of the V-Drive very clearly says dexron iii. Can any one help me sleep at night that I put the right fluids in?!
    I can add some pictures if it would help.
    Thanks!
  • hal2814
    • Jun 2016
    • 548
    • Ft Worth, TX
    Do you have pics? SHC 50 is the “lifetime” fluid used in the PCM v-drive. Do you have that or do you still have the Wolters unit in 2007? Are
    you sure you’re not looking at the transmission?
    • H2O
      • Jul 2006
      • 247
      Your boat has both a Vdrive and a transmission. They take vastly different fluids. The transmission has a yellow handled dipstick. It takes Dexron lll (Dex-Merc) red-colored transmission fluid. The Vdrive only has two square headed bolts sticking out at a 45* angle for access. It takes the yellow colored synthetic 50 wt fluid only available at dealer nowdays. It sounds like you mistook the transmission for the Vdrive. The owner's manual is downright misleading in regard to which unit it is refering to.
      • bturner
        • Jun 2019
        • 1742
        • MI
        • 2016 200 Sport Nautique
        I read the manual about 10 times and still almost made this mistake on my boat when I first got it. H2O is absolutely correct. Be careful what you're looking at and which you're changing. Unless something has gone wrong you should only be dealing with the trans.
        • Sinclr12
          • Sep 2020
          • 2
          • New York
          • 2007 - SAN 236 TE
          You guys are life savers, everything mad sense in the bot then the manual made me second guess what I was seeing. The plate I am seeing with dexron is the tranny. The manual makes it sound like I don’t have a tranny!
          thanks again!
          • Infinity
            • Sep 2017
            • 730
            • Lake Norman - Denver, NC
            • 2014 SV244 w/ ZR409
            Here are some pics for reference.
            1st one is the v-drive (has the square head cause it supposed to be a 5yr fluid....this is the Mobiltrans).
            2nd is the transmission with the DEXIII
            3rd pic shows them both
            • shag
              • 2217
              It can be confusing. A good way to remember is that the V-Drive is the last assembly in line. (It makes the V in V drive).
